Need help
snicklas
6.0 and Loving It!!
Staff member
Administrator Moderator
Greenfield, Indiana
Need a bit more information, as 94 is an odd year for Ford Trucks.
Is this an IDI, or a PSD (I see that it's in the PSD section)
Automatic or Manual?
So if this is a 94 PSD, it should be a manual..... Ford didn't put an automatic behind the PSD in 94, only behind the IDI
aggiediesel01
Houston, TX
here’s website that will create a list of wrecking yards in your area that have transmissions that should fit your truck when you fill out the web form. Be sure to select that you want a “non-interchange” part and select the years of ‘88-‘93 and diesel to get the correct transmission
https://www.car-part.com
Oiler
