need help with upgrades 2006,6.6L,2500hd 4x4
captmike866
Orange Beach, AL
she's a bone stock 2006,6.6L,2500hd 4x4. Which upgrades and product manufactorsdo you think? Where to start exahust or intake? I would like to lift the truck only about 2-3 " just to get a little larger tire onboard. Must stay hwy driveable. What about engine programmers? their everywhere. exhaust sys / turbo back or cat back? Any help or just opinions would be great.
Thanks, Capt Mike.
dieseldummy
Lost in time
CO
I'd do exhaust first, IMO. Lowers EGT's moreso than an intake on a Dmax. You can turn the torsion bars up to fit larger tires, and maybe add a leaf to the rear spring pack. I'd stay away from a programmer unless you are prepared to shell out $12,000 for a new motor. There are several reports about cracked pistons in the new motors stock, much less with added HP.
Justin
rebel_horseman
Rt. Wing Extremist
West Florida Republic
Exhaust is always a good upgrade followed by intake. Go with a full 4" system turbo to tail. Don't waste money on a programmer. You can get much more and much better power out of something like the Edge Juice - Attitude combo. I still don't understand why people feel the need to lift a 8000 lb truck. It's not an off-road truck and lifting it too much will screw up the towing abilities greatly. Stock you can run 285's easily. If you really want to go higher, get a set of torsion keys and that will give you an inch or 2 and you can run 305s.
TLBREWER
Windy B Ranch
Moriarty, New Mexico
As far as suspension. Check out Cognito Motorsports leveling kit. Good for 2-3inches in front. Be careful because the more you read, the more you'll find out how GM screwed up the front geometry...making it expensive to fix or modify.
As far as programmers, etc. I agree with the others. Not really necessary, but if you do, it will void your warranty. Consider beefing the tranny first. That warranty is up at 36K anyway. Go with a cat-back (removing cat also voids warranty). The intake on the LBZ is as good as it gets until you modify to the point where you need a lot more air. You might get a little better flow by changing the ducting, but the filtration is plenty. I think most change it because the $300 intake system looks cooler. JMHO
Tom
olsen726
