Well, I've been doing this exact same thing the last couple of days. I've taken it out twice, and put it in 3 times since these last couple of days. Yes it is a *****, and you will be swearing like no tommorow however you do it. I put the pedistal in, and then the turbo. I held the exhaust gasket in with some grease so it would stick to the turbo when I installed it. Its definatly easier with more than 1 person, but its do-able. Make sure if you do this, to install the studs that mount the turbo to the turbo pedistal into the turbo before installing, then taking the bolts and tightening them up. I tried it with the nuts on the studs and then put them into the turbo, and I ended up having an oil leak because I didnt align it right or something.
