Cheaper Jeeper
I'm a cheaper too. In my head driveline has always transmission to diff. I was just checking to make sure you meant the driveshaft was there.
That would be drive train wouldn't it?
I can vouch from experience on the mileage of the 126. I get about 25 mpg and about 400 gallons to the tank on mine. It used to be a lil less like 21-22 range before i replaced the injectors. Since i replaced the injectors it has been running good. Albeit other problems have arisen since then.
ODO says 201k - and based on what paperwork/carfax the guy had it appears to be pretty close, but no way to know exactlyman thats a nice MB how many miles ?
You betchaI see you got a turbo deisel
I'll check those out....
Yeah, I thought about that, but a new one is very spendy, a used one is going to be 24 years old - so it may crack in short order too (if you can even avoid cracking it getting it out or installing it) and the cover I'm talking about is less than $150. It isn't one of those pieces of carpet - it is made of ABS plastic colored to match the original and vacuum formed to look like the original dash. I put one in my 280 Z and it looked great. If you didn't know it was a cover, you wouldn't even notice.I would try to buy a new dash or get a junk car dash before a cover it look alot better
didnt those 6s have problems with the head gaskets with the aluminum heads.
