ok im not in the greatest mood so ill get to the point
2000 F-350 175,000 miles
big oil leak and could see a river of black in the valley going from the front of the motor running to the back and down the bellhousing
took the fuel filter bowl off and whole passenger side was wet..high pressure line going to passenger side head was oil and split loom was full..replaced the line and fitting that goes into the head
got it back together and it still leaks but im not seeing a river like before so idk if multiple things were leaking before but its still a stream of oil not drips
could the turbo pedestal leak this bad? im thinking its the high pressure oil pump but i just wanted to hear your oppinion
