Lots of idi parts
gonecrazyi
florida
I've got several motors, transmissions, t cases and body parts that need to go.
One 6.9 block that is almost completely torn down. Been sitting outside for a while. 150 for block with heads.
7.3 turbo motor, ran great had 150k on it. Bad oil cooler put water in oil. Only ran that way for a few minutes and the oil was drained. I pulled it and took the turbo and the motor has been sitting for about a year. 350 obo without IP and 400 with it.
1 set of 7.3 turbo heads 150, been sitting awhile and will need a rebuild.
Lund visors - 3 of them. 80 apiece, one is lite but is missing a few light caps.
T cases - 60 apiece
Cab n chassis rear with LSD and 4.10s with 3 inch lift blocks- 150 with rims
83 bed good condition with a few rust spots in the bed. 150 obo
83 dash pad, red with no cracks or holes - 70 obo
94 4x4 e4od. Worked before engine pulled but hasn't been used in awhile. Comes with flex plate and new convert or - 300 obo good as core because I can't show run it for you.
Sever
al crew cab front and backs doors - 50 apiece
Dana 60 reared with 4.10 gears. 150 obo
Doug Nash box for a 2wd c6. Don't know if it works. Most of the wiring is there. 150 obo
87 10.25 rear with 3.55 gears - 250 obo
83 6.9 ran good but leaks coolant from front of motor. Haven't looked to see why. IP also leaks fuel. 100 obo
Several obs diesel core supports- 175 obo rust free
Lots of other parts - just ask and ill let you know if I have it.
Pics on request..
jam0o0
houston, tx
i'm looking for a visor with the lights. wanna ship it?
also interested in the LSD and 4.10 if you wanna separate them and ship them, and if they are for a sterling.
if you have any pictures i'd like to seem um before sending money.
t-cases: i need a ford 203. hum maybe a pallet freighted over here would work...
gonecrazyi
florida
Let me check on the torque converter . Ill get pics tonight or tomorrow of everything. Ill have to check what the cab n chassis rear is and ill let you know.
blackflag
Maryville, TN.
I would be interested in one of the visors without ligjhts and would need them shipped to Tennessee. Please let me know if this is something you would be interested in doing. Thanks.
Tim4
Md
I'm in need of a flex plate for 6.9.
gonecrazyi
florida
Here are some pictures. Ill ship pretty much anything. But the bigger items are up to you to arrange freight. I can pallet and drop off though..
gonecrazyi
florida
Ill get some measurements for the visor and get shipping quotes for the two of you who want the lite one. I just need zip codes.
jam0o0
houston, tx
77489 for me. that dually axle is a sterling. easiest way i know of to ship the gears and carrier out of it is to put them in a cheap igloo cooler. they don't treat cardboard boxes to well.
gonecrazyi
florida
I've got several good oil coolers. A few of them are the upgraded turbo models. 25 apiece. I haven't had any luck selling the entire axle so ill see about pulling the gears sometime this week. I want to look at them and get you a pic before we figure a price.
BrannonB
