Looking for a few things...
93fordturbo
La Crosse, Wi
Im looking for a compressor for my ac. I think thats what its called... the one that runs on the pully. Anyways, should i pull one off a junk yardtruck or get a new one. I know people say i should go new, but money is tight. How important is it. Plus, i need a wiring harness for everything behing the cab, not including the tank. Just the lights. I have one brak light that works, and one blinker light that works. Also i think my revo lights work too, but everything is so damn cobbled up and spliced i just want to re do it. Any place i can get a harness for that? Any one have one that will work? Thanks in advance
A quick fix for the wiring would be the four conductor 14AWG used for RV's, it has Green, Yellow, Brown and White conductors. Green for the Right stop/turn. Yellow for Left stop/turn, Brown for taillights/Lic. White for Backup. When splicing, solder the joints and coat with liquid tape and then plastic tape over, or use shrink tubing. Check your grounds at the lights and bulb contact for corrosion.
If I can find the SOB that stole all of my 100 A/C compressors fully charged with 134A I would give you one. They were take offs from Diesel RV Motor Homes. I know they would fit.
crispy74
