Found instructions:
Warning: Turning the fuel up on your engine will cause more internal heat that could melt your aluminum pistons. It is important that you be conservative with this adjustment and carefully watch your EGT (exhaust Gas temperature). High EGT can cause piston damage. Buy and
install an EGT gauge to monitor temps. I do not have a gauge yet, but I have set my
pump conservatively and do not see a lot of black smoke which is unburned fuel. High EGT and black smoke go together. I do not tow or hold the engine at full throttle for more than a minute or two in traffic. If you tow frequently or use maximum power for extended periods high EGT temps will damage / melt pistons. Short EGT spikes are not a problem because they don't keep the pistons hot for long enough time to hurt them. If you ignore my advice and turn the
screw up all the way you run the risk of ruining your engine.
I turned up the fuel by taking off the small cover on the drivers side of the
injection pump. It is very small, and has 2 screws holding it on. You will need to remove the throttle cable and bracket to see the cover. Once this cover is off, a little bit of fuel will spill into the engine valley. What you are looking for is a small 5/16th Allen
screw under this cover that appears through a small access hole. The
screw rotates as the engine rotates so you will need to have a large ratchet or breaker bar on the crank pulley nut to rotate the engine while you look for the
screw to appear in the access hole. You will need a small flashlight and mirror to see this
screw. At first it seemed like there wasn't enough room, I swore I would have to remove the intake manifold. It helps to have a buddy turn the crank while you watch for the
screw, but I did it my myself, it just took a lot longer. It does help to remove the throttle cable bracket and detach the throttle cable from the
injection pump. You may also have to move the throttle linkage to get to the access cover and fuel
screw.
Once the
screw is in sight use a good quality 5/16th allen wrench to turn it. To increase fueling, turn the
screw clockwise. It helps to turn it in small increments. I turned mine 1/6th of a turn ( imagine from 12 O'clock to 2 O'clock) This gave a good fuel rate to match the increased airflow from a K+N air filter and Kascar (
www.real4wd.com) resonator exhaust pipe. I could have possibly gone to 1/4 of a turn clockwise, but I wanted to be conservative. It is important to increase airflow along with the extra fuel or you will just put out a lot of black smoke without any extra power. Once the
screw has been turned put it all back together and enjoy.
