Greg Pettit
Guys, I need some help. I recently replaced the axle u-joints and the wheel bearings up front on my '91 F350 w/ Dana60.
Everything works awesome.
But, I noticed a little spot of gear lube the other day dripping off the steering knuckle.
Thinking it was residual from the work I had dome, I tried to ignore it.
But, I have seen the puddle a couple of more times, and am thinking that the axle seal may have been damaged when I had the axle shaft in and out.
If that's the case, how do you get to the axle seal? Pull the differential out of the case?
Thanks for any and all info,
Greg
Greg
why that couldnt be made easier!!!!! and you put the seals in from the inside!!! like tow did, i made a rod--that i could put the right size socket on the end--and then drove the seal in--and get it in straight from the start--if its cocked, and you keep driving it in---youll either ruin it, or when you get it completely in-itll be "bowed" slightly,and leak!!! around the outside, not the axle seal area-----been there only once at the cost of the seal--and at the time--i could only get the seal form ford----also----clean that axle tube out while you have it apart!!!!!!!!!!!!!
