Key fob battery?
jvencius
In a van down by the rive
Is it possible to change the battery in the keyless-entry key fob and if so, how do you do it? Mine finally quit working and I can't find the second key fob. The key works fine in the locks, so that's not a big deal but being able to use the keyless entry is a nice convenience.
NJKen
is a daddy!
Central NJ
Easy fix.
Take the fob off the ring and use a screwdriver to split the case apart. It just snaps together. Once apart take the battery out and go to radio shack with it. It is a common size I just dont remember it ofhand. Most large auto parts stores will have them too. There is no need to reprogram them when changing the batt so all should be good.
Ken
TimMiller
Houston, Tx
What does fob stand for. I know what yall are talking about. I got new batteries from the drug store.
Mike
Stroker
Cora
fob 1 (fb) KEY
NOUN:
1. A small pocket at the front waistline of a man's trousers or in the front of a vest, used especially to hold a watch.
2. a.) A short chain or ribbon attached to a pocket watch and worn hanging in front of the vest or waist.
b.) An ornament or seal attached to such a chain or ribbon
TimMiller
Houston, Tx
95_stroker said:
fob 1 (fb) KEY
NOUN:
LOL. Thanks.
jvencius
I replaced mine today while at Advance Auto with Rampy--the fob takes a CR2032 battery and replacement took all of 30 seconds. The keyless entry works now and that's a good thing. :thumbsup: :thumbsup: :thumbsup:
