Inter cooler FS $355.00 OBO PRICE DROP
I'd like $355.00 OBO or swap for WHY for this IC, I have no tubes to speak of...for it.
Kinda looking for a set of 4 Vbar chains to fit PREFER 315/75/16 take 255/80/16 would work...need four chains
Plate along bottom to mount can be seen
This unit is JUST wide enough to pass the outside edges of the WIDE SHORT Non AC rad.
Here you can see what I mean, It is not perfect but I think it could be made to work fairly simply.
Dimensions are as follows; OVERALL= 45 1/4"x 13 3/4"x 7 1/2" (including in out tubes) CORE = 36 1/2"x 13 3/4"x 3" Inlet and outlet tubes are 3 1/2" OD dia and 3 5/8" deep, this could be modded easily as it's a welded construction.
BIG indeed!
See the way this just fits over the width of the wide rad.
There is little clearance on each side but as said, this would need some fab to make work
Construction inside very nice indeed
One small ding 2 1/2" showing,this is on the inlet outlet side not the section facing the front of truck...that was repaired with what appears JB weld, I'd suggest that be welded up and your golden...JM2CW
BIG indeed!
winter coming wants yard clean...shop don't got nuff space for all my parts
