foresterdj
Well, I am now fully indoctrinated into the IDI, air leak no start crowd. I bought my truck in March and at that time it had the 20 year old original fuel return lines, which must have leaked like fountains, since at that time the top of the engine had pools of leaked fuel. I changed those out a day or two after buying the truck and after a couple runs, the engine top was bone dry.
Truck started good all summer, especially after the new Beru glow plugs, Rrr, Rrr, Vroom.
A couple weeks ago, Rrr, Rrr, Rrr, Vroom, Hmmmm.
A week ago, Rrr, Rrr, Rrr, Rrr, Rrr, Vroom, Hmmm, well it is a bit cooler than summer, and batteries do need replacement before winter, but wait, the injector and fuel return line 2nd from rear on passenger side it wet. Hmmm.
This morning, 32 degrees, glow plugs cycle maybe 11 seconds and Rrr X 7 or 8, and Vroom, Hmmm. Hook up Jon boat and head to the pond to see if any stupid local ducks are still around. (None were, all well trained to stay far out of shotgun range.)
This afternoon it is Rrrr, X about 10 or 12 when it is rrr rrr r. S**t. Get out portable jump start unit, Rrr, Rrr X ~10 then pop pop pop...pop pop pop, vroom.
Do not shut off again until home, both rear injectors on passenger side seem wet. Same two that leaked a couple days after installation last spring, then dried up. So I guess I'll be putting in some new O-rings in those this week. I am assuming the new lines should be o.k.? May as well do the batteries while I am at it, was going to do them this fall anyway.
Any hypothysis on what makes 7 month old O-rings start to leak?
YES IT IS!
