GOOSE
Happy IDI'er
My truck has a vibration that has been bothering me at highway speeds. I am ordering a new carrier bearing just to eliminate the possibility of that adding to the issue. The real crux of the problem is the pinion yoke. the ujoint moves side to side within the yoke to the tune of about a sixteenth of an inch or better. The yoke itself has come loose before and my trans rebuilder tightened it and noted the worn yoke.
Can this be done without removing the axles, carrier and such? I have read that there is a crush sleeve eliminator but don't know if that saves any work. I haven't gotten into tearing rear axles apart aside from a 9" Ford about 17 years ago now. Is this a day job with simple tools or should I have a garage that's versed in differential work do this for me? I am familiar with bearing preload and the ring and pinion meshing correctly but am kind of out of tune as to whether I should order parts and tackle this myself. Should I find a long yoke rear and work with that at this point?
