h2odrx
Anti-O
Ok last couple of days she cut off on me in the middle of the road. It would run ruff miss fire and shoot white smoke out the tail pipe. then die let it set for a few and it would fire right up. so is it water in the fuel? so i order a new separator filter and pick up the new fuel filter and change it out. the separator when i drained it looked like the last few times I've drained it, about 1/4 gunk and some water the rest clean fuel. then i check the fuel filter it was 1/3 water (clean and clear) and 2/3 fuel? whats up with that?
also on a side note i hooked my block heater back up and plugged it in and it makes a hissing sound?
