basilbowman
Hey guys - so here's the deal.
About 340 miles ago I started getting fuel starvation issues. I'd be going up a hill and the truck would lose power and die, like it had a clogged fuel filter. There would then be a period of really having to crank on it to get it going again (mildly nerve wracking to have no start in traffic) and it would seldom catch, usually it would just start and die unless I really revved it up to 1800, and even then it wouldn't necessarily stay there. After swapping a couple of filters out, that wasn't the case, so then I changed the lift pump. That got me home from TN, but then the next day it wouldn't start. After sitting a day, it started, hard, and idled but wouldn't run uphill. The return lines were really rotted out, so I changed those last night, started it and idled it for ten, fifteen minutes, then started down the driveway, running downhill at maybe 1000, 1100 rpm to see if it would do anything, and yup - dead again.
Should I go get another lift pump? Is there a poor man's way to check the injection pump? How about the injectors, this couldn't be related to them, could it?
One more thing: When I had a buddy of mine turn it over while I pressed the relief valve on the fuel filter, mine hissed air at first, then spurted bubbly fuel, while his truck (same engine) had no hissing and clear fuel. This was yesterday before it died on the side of the road and I can't check it now because I don't have anyone to crank it while I press on the valve, so I don't know if changing the return lines did anything to help with that.
Any advice is greatly appreciated, I'm a bit at a loss as to my next move
Thanks,
-N
Thanks,
-N
