help cold start
Goose_ss4
ca
OK i am having some problems with my fast idel and cold advance.
I am not getting power to the cold advance nor the selonoid for fast idel. I bypassed the selonoid and it does work, but with the wrire hooked nothing. I did the same for the cold advance on the pump, but couldn't tell if it worked or not. The sensor for this system is on the driver side front correct? Head?
Finally i think my glow plug harness is done, so i am going to make my own. For those who have done this, what size wire did you use, and do you have a pic or drawing of what you did?
Thanks
94 7.3idit
smolkin
Stuck inside Mobile
Mobile, AL
When I made a up a new harness I used about 20' of 12-gauge wire, automotive-rated to resist gas/oil, 25' of split loom, 8 bullet connectors (14-16 awg but I made 12 work), 2 large 6-8 awg lugs, and about 12" of 1/2" heat-shrink. I ran a separate wire for each plug and crimped them in banks of 4 for each lug, then split-loomed everything and put 1/2" heatshrink pieces at all the joints in the loom. So far so good, just don't forget whatever you do, to measure 3X and cut once! I wish I had a pic but I guess I forgot to take one. :(
My cold start circuit isn't working either, maybe someone else has pointers on that...
smolkin
Stuck inside Mobile
Mobile, AL
Goose_ss4
ca
Would that work on my turbo motor? Controller on valve cover?
