Piece of cake.
Firsdt ya gotta remove the batteries to get to the 2 nuts that are on the back side of the core support.
10mm IIRC.
Ya also gotta remove the grill. 4 screws and it will be retained by a few snap fittings near the screw locations. Should come right out. There will be a couple of nuts also on the black headlight mounting bracket 10mm also I think. The headlight assembly should come right out. One thing to watch for is the nuts may be rusted onto the studs and can strip out the studs, when removing, which are mounted into the molded plastic. Some penetrant of yer favorite choice should work.
From there it should be a snap on removing the lenses from the assembly. The marker lights will also be attached to the assembly as well when it all comes out.
If the studs do strip out on removal. The ole JB Weld did the trick on the repair.
Here's a couple of pics on the general location of the 4 nuts to remove the assembly.
