headlight questions
res0wc18
Everett,Wa
hey guys is there a way to make the high and low beams stay on at the same time on the 1997 f350's?
res0wc18
Everett,Wa
that looks great. so does that just plug into the headlight switch and then the other end to the harness or?
Mike
Stroker
Cora
From the website........
Brite Box features easy plug in installation (in most vehicles) and can usually be installed in 30 minutes or less. There are Brite Box models available to fit most domestic cars, light trucks, and sport utility vehicles (SUV's) manufactured from 1976 - 2004.
Give Bob or Shirley a call and tell'em OB sent ya!
res0wc18
Everett,Wa
could i use this in combination with the hid kit like weve talked about earlier, just like the one big ken has?
Crumm
No Comment
Fairbanks, AK
no one?
No. The hid high/low only has one bulb. When turned to high beam the bulb is just moved to a different angle. You would probably ruin them if you tried.
bob123456789
