For some time now I have been researching the deck to block thickness of our heads. The measurement is taken from the machined valve cover rail seat surface to the underside of the head machined surface. Factory oem specs are anywhere from 4.805 down to 4.795... Now if the valves are all set to the proper depth in the heads why can't the heads be less than the 4.795 thickness... We have a hydraulic roller lifter than will "find" the balance it should run in. The rocker geomotery wont change because of the thinner heads. I'm just not finding why we must stay in this 10 thousands tollerance. A head cut down 10 od 20 thousands with the valves all set properly in the heads will not be changing the compression ratio. Our heads are flat without a combustion chamber in the heads like a gasser has... Anybody have some ideas on this....
and I haven't sen a 7.3l and 6.9l head side-by-side...thank you again
