fuel? issues
jwalterus
Made in America
Air Force
Garrison, ND
Glad you got it running; now you just need to find out why it quit.
I put this here just so others will know :
On ANY diesel system, if the engine fires and is running, there is ABSOLUTELY NO BENEFIT gained from "cracking" injector-lines.
There is no need to "bleed" the lines if the engine will start.
Further, the IDI system CAN and WILL self-bleed, so no need at all to manually bleed anything on an IDI = forget that tempting Schraeder Valve is even on there (it is for checking fuel-pressure).
A running diesel engine will not so much as hiccup if a little bit of air happens to pass through the system.
What WILL cause problems is a LARGE amount of air with NO FUEL, thus it momentarily runs out of fuel; and, enough air will cause the lift-pump to lose it's prime. ;Really
thank you very much for the information, I am not 100% sure how I got fuel into the lines, but it was probably from the rear tank being under 1/4 tank and having it idling on a side slope, my rear tank registers 1/4 at 2 gallons I found out, gotta love the stock gauges (pay attention all you others who are new like me)
first off once you introduce air to these fuel systems it is very hard to get them out. some ways to get it out is by cracking open a couple of fuel lines, and watch the bubbles out. or my personal favorite go on a govenor running, and wine the **** out of it to expel any remaining air. might not get all of the air out, but it really helped my rig. also by adding a new fuel filter is just another way for air to get it. on the fuel filter assembly there is a shrader valve that you can press to let the air as well.
it wasn't hard at all, I made sure I was on my front tank which had plenty of fuel, replaced the fuel filter with a new one full of fuel, and that was that, I cracked my fuel lines for 2 reasons:
a) I wanted to make sure all the air was out, even though the truck was running fine, I didn't know I did not need to do it
b) it let me make sure all my injectors were working properly, I have not yet had the truck a month and want to make sure it's going to run good for a long time
the schrader valve........ sounds like a good way to get a faceful of wasted fuel.....
as far as running wide open on the governor for long periods of time to get air out of the system, sounds like a great idea....... cookoo if you are trying to destroy an engine......:eek:
tke395
