FSV wiring harness question
notenuftime
Pennsylvania
I bought an aftermarket FSV made by BWD, I need to wire in a new harness that i got with it since the original FSV was blade connection this one is a pin. the aftermarket harness is lettered A-F can anyone tell me where i connect my wiring in order?. here is some pictures of the harnesses and wiring.
Do you have a diagram of the new harness? I hope its in the instructions. The original harness is;
Brown/white and red are the valve motor wires
Darkblue/yellow is the wire that goes to the front sending unit
Yellow/lightblue is the wire that goes to the rear sending unit
Yellow/white is the wire that goes up front to the fuel gauge in the dash.
notenuftime
Pennsylvania
here is the diagram from FSV, here is the way i read it does this seem correct?.
E= brown/white valve motor
D= red valve motor
C=yellow/lightblue rear sending unit
B= yellow/white dash gauge
A=dark blue /yellow front sending unit
DrCharles
West Plains, MO
There's only one valve motor - the polarity is reversed by the selector switch to change between front/rear.
I am pretty sure that + on red, - on brown selects the front tank. Will check the schematic to make sure.
DrCharles
West Plains, MO
yep... front tank is +12 to the red wire, ground to the brown/white. :)
  • F250 fuel tank wiring.pdf
DrCharles
West Plains, MO
Somewhere on that instruction sheet (looks like the same one that came with my Standard Motor Products valve) it should say explicitly which wire is +12 and which is ground in order to select the front tank... let me know.
notenuftime
Pennsylvania
Here is what it said. ( If using toggle switch, cross wire as shown. Connect one pair of terminals to a good ground and the other pair to a +12 VDC source through a 10 amp fuse.
If i think i'm reading this right looks like E= red and D= brown/white. thoughts?
DrCharles
West Plains, MO
Not trying to be difficult but that depends on which way the switch is mounted and whether front tank is up- or down-toggle... :)
Somewhere in the fine print on that diagram, I think it still says which wire is powered (D or E) when you want front tank. At least it did on my SMP valve.
I recommend at this point that you simply hook it up to a 12 volt source and see which nipple you can blow through...
notenuftime
Pennsylvania
found this by Franklin 2 on another diesel site.
1->F
2->E (Main Tank)
3->D (Aux Tank)
4->C (aux tank sender)
5->B (fuel gauge)
6->A (main tank sender)
If this is correct than my red wire will connect to E and brown white to D ?. o ya and toggle switch in cab is up front, down rear.
