Front end pop
So if I backup and hit the brakes, I get a pop. Can feel it.
Then when I go forwards, I get the same thing
I need to look at my ball joints, I know the track bar bushings are bad. (I've been trying to stuff 50lbs of cats in a 5lb bag)
Looking at my spring plates at the axle, and it also looks like something could be cockeyed.
The oiled one is the driver's side. (Trying to prevent some rust LOL)
ROFL.
Pics may not have been straight on.
The spacers are for sure crooked, but I can't tell if the axle is also.
I guess I could measure from the spring hanger to the axle, on both sides and compare?
It doesn't seem to pull that much, but with a floppy steering wheel, it's hard to tell .
Could somebody help me with which energy bushing kit I need?
I don't have a front nor rear sway bar.
So leaf springs and track bar.
I'll do body bushings later, unless I could get a complete set for less.
94 f350 single cab dually.
Thanks.
RenoF250
Sierra Foothills, CA
Didn't think of that. LOL
I was trying to look around and see if anyone had said what they used, but it's like I'm the only 4x4 f350.
Were f350's supposed to have sway bars?
Well I've done the balljoints and track bar bushings.
I'm still getting a pop.
Upon closer inspection, looks like the axle is maybe moving a tad bit. I can see it where the little spacer block is.
So can I just try tightening the u-bolts? Or just replace them?
Still going to do the spring bushings eventually.
Leeland
Oregon
Common practice on trucks and trailers is to tap the u-bolts with a hammer, you'll know when you have a loose one. Little duller then the rest.
In the shop on big trucks u-bolts are a 1 time use only unless the customer insists and signs a waiver. At home on a light duty vehicle, fug yes I've re-used u-bolts. Almost $100 per axle for longer ones any way. Every one will have their feelings on it but mine were almost new. No obvious stretching or damage so threw them beaches back on.
Should be fine re-tightening unless they're seized. If that's the case if it were me I'd replace. Pretty much the same at work, but there if it comes apart it goes in the scrap bin.
Forgot about the tap test.
But I got pics and did tighten them some. Had to be fairly loose. I recall seeing something like 186ft/lbs for the torque.
I moved a few fairly easily with a crescent.
Leeland
Oregon
The bright orange rust like that is usually a pretty good indicator of some movement.
Torquing u-bolts? Nah, only if they're new then torque them again after a few miles. Used may have dirt in the threads etc that will obviously negate using a torque wrench and therefore I just hit them with a impact till they slow to barely moving and obviously have drawn tight.
When you go to do bushings might as well as get new pins for the leafs if you plan on keeping those flat leafs. I'd at least clamp the leaves and pull the pins to inspect them after having that spacer move around. More likely to shear a worn pin then break u-bolts.
Sgtbyersfw
