IIRC Lumy timing is measured ATDC, I've yet to see a timing light that will retard past 0* So you would literally have to measure and mark new timing lines on your balancer.
At least that is what I remember from the last discussion on the Fox adapter.
However don't they have a 20* offset setting? If so, then you should be able to use one.
