Fluids
dyoung14
Is getting worn out
spencer,tn
What kinda fluids is recomended for the axles the tranny the transfer case all of it i need to know, thanks
Pearl_Diesel
Pearl/IL/USA
If I was at home I could read you out of my haynes manual, but I'm sure some other guys could give you an answer sooner than 7 or 8 oclock thisevening.
hesutton
The Anti-Anderson
Bowling Green, KY
For the T19, gear oil. I'm running Mobil 1 synthetic 75w-90. I've not noticed a single improment over running coventional 75w-90. The axles will need gear oil too. 75 to 85w-90. If you have a limited slip differential, you need to add friction modifier to keep it working properly. The T-case will need ATF.
Heath
dyoung14
Is getting worn out
spencer,tn
im not sure if i have limited slip or not, but i know so far everythime i seen it spin it has spun both tires
crispy74
