What is the SMF Lucky mod? How in the world do you put 2 gallons in a ZF?
Mine only holds 3.5 qts
Dan
ZF5 is supposed to hold 6.8 pints.
The Lucky Mod is a Dual Mass Flywheel converted to a Single Mass Flywheel, using bolts, to tie it together. The extra oil is used to dampen gear roll over noise from the Single Mass flywheel.
