"Works! I know this post is older, but if anyone else comes across it in their search for a fix to the same issue, read this thread from start to finish. On the 96 F250, You'll see the factory AMP located under the dash above and just right of the gas pedal. (Somewhere in that area) Another sure way to find it is moving the factory in-dash wiring harness for the head unit around. You'll see the proper harness moving under the dash and you will see that it plugs in to the silver factory AMP. However, if you are lucky enough, you don't even need to see where this is located. If your head unit has the remote wire (blue) just hook it up to the blue remote wire on the wiring harness you purchased to install your new head unit. (Should be marked AMP). Basically, just hook the head unit up to the aftermarket harness you purchased, not leaving anything out and don't leave the remote unhooked as you normally would without needing to power another device. Hook the remote up as if you were sending an on/off signal to your aftermarket AMP for subs. No different. bad12jr shows an excellent illustration of the after market harness in this thread and is dead on with his instruction. Like he says, if it will not work straight up, wire the blue to the red. Just make sure, somehow, that your factory AMP is powering off when you turn the vehicle off. "
Found on another forum, hope this helps
