Essential IDI spares for remote areas and extended journeys?
towtruckdave
Resident Nutcase
Cleveland,OH-Nashville,TN
My IDI is a 1990 F250 ext cab 4x4 zf5 truck. In the toolbox I keep:
*Tools: sockets, wrenches, screwdrivers, side cuts, hammer, breaker & lug nut socket, wire
*Starter
*alternator
*belts
*hose repair (sleeves, clamps)
*5 gallons antifreeze
*oil,atf,brake fluid,gear lube
*2 injectors
*silicone sealer
*vacuum pump w/pulley on it
*rain-x
*nascar jack, spare tire in bed, plugs, 12v air pump, fix-a-flat
*fuel filter, oil filter
*r134a
*drinking water, beef jerky, heater meals, gas mask
*big knife
*pb blaster, gumout
*spotlight, flashlights, lighters
*small propane torch
*something that goes bang
*sawsall, inverter, ext cord, wood and steel cutting blades, grinder, drill
*zip ties, duct tape
*headlight switch
*j-b weld
*20' 3/8" chain & snatch block (for the winch)
What am I forgetting?
Rot Box
Northern Utah
Lewiston
Headlight switch.
Fuel pump.
Upper and lower radiator hoses (for when your belts give out and take them out with it).
Ether.
Earplugs... In case your wife is very vocal like mine :rotflmao
TWeatherford
Flagstaff, AZ
How about some fuel line, extra plastic injector return fittings and hose, superglue, fuses (surely you have those though), glow plug/starter relay. I also carry two lug wrenches. 1 factory, and the faster, more convenient X-style. Though my x-style lug wrench is well made, I'm scared that if the weld ever breaks, I'm in trouble.
Simp5782
SNOW TACKLER!
Western MT
um. the kitchen sink? an M1 tank? some deuce and a half wheels and tires? (for incase a convoy is broke down). Throw the fix a flat out or you will **** the tire guys off who fix your flat. and all i can say is. That must be a damn big toolbox.
Diesel_brad
Dunce
gilbert pa
For a truck that is so reliable you guys sure cary EVERTYHING:dunno
I carry a spare tire, bottle jack and a lug wrench
gatorman21218
Ashland VA
An assortment of lightbulbs.
tubing/hose of different diameter
a wiring/electrical kit
a bottle of fast orange hand cleaner
a medkit
paper towels/rags
a blanket
maybe some small boards to put under the jack if the truck is in grass or uneven terrain
some clear packing tape to "make" a window
a pouch of redman
burtcheca
farmer/cabinetmaker
Live Oak, Fl.
A compass, maps, matches or a lighter and toilet paper.
This is getting interesting! You are getting close to my neck of the woods!
I like the part that goes bang. I always have my 586 under my seat, not in my tool box, and enough ammo not too far. And of course survival knife and my Army machete.:backoff
Burt.
towtruckdave
Resident Nutcase
You are right about the wife. :yell:
Headlight switch is on the list. Good call on the fuel pump, I forgot to put that on the list but there is an extra pump in there somewhere near the bottom. ;Sweet
Some excellant ideas, like plastic injector pieces. I have o-rings in there. Hand cleaner and rags is a big one I forgot.
I will need some fuel line and clamps.
I cannot believe I forgot fuses and bulbs. And a relay.
Toilet paper. Whoa, might need that. :eek:
A medkit! Thanks, gotta get that. Well I got duct tape. :dunno
towtruckdave
Resident Nutcase
:rotflmao LOL ....in case a convoy is broke down....
burtcheca
farmer/cabinetmaker
Live Oak, Fl.
Air bed, pillow, blanket, tent, some extra clothing and a wind-up/batteries radio with weather band.
You said "remote areas or extended journey", right?
Burt.
how bout a fire extinguisher....maybe a spare throwout bearing...oh wait u said atf....sux to be u....
bike-maker
albany, OR
Bailing Wire, 1 can of chew at least half full for emergency radiator repair.
How about a block of wood for blocking the air intake in case of a engine runaway.
JU57US
