DNE2
rjjp
Needs to go test
Clare, Mi
Does anyone know of a source for adapters for the DNE2, I know where there is one on a 2wd C6 IDI, but thinking about putting it behind a transfer case if possible.
Diesel JD
Gainesville, FL
If you can't use the adapter that comes with it, you're going to have to make your own or find someone who can. They are pretty simple and great units from what I've been told. I had one but it turned out to be an under drive box and I got frustrated and just sold it off dirt cheap on ebay due to being pissed that it was an U/Drive and having a hard time adapting it to my long shaft T18.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
I don't know if there's a way to adapt a 2WD Doug Nash to go behind a transfer case...keep in mind, the 4x4 DN's went between the tranny and the transfer case, and IIRC the GearVendors 4x4 unit actually came with a replacement for the back half of the transfer case so that the unit would have something to bolt to.
Beyond that, U.S. Gear is not supporting the units in any way anymore, as I learned in a very terse E-mail response to a question I had. Anything's possible with fabrication, but methinks you have your work cut out for you...
