You have the Sterling 10.25" rear end, just like I do. Bullet-proof and easy to work on. The OEM LS was the Trak-Lock multiple disk setup. From the factory, the break-away force was set kinda light, but with a shim kit, they can be adjusted to do a great job. The downside is that like any multi-disk setup, as the disks wear out, the LS ability decreases. You might wanna consider a PowerTrax unit. They're designed to fit inside your existing open carrier with a minimum of install fuss. I'm going to install the OEM PT system in my diff this Summer, simply because I have a complete unit sitting on my shelf. It won't be as effective or live as long as a mechanical unit, but I can't beat the price!
