Though similar a it is not a TRUE cross over steering which the D60's do not have wither they use a semi cross over....the tie rod does not go the the RIGHT hand knuckle and then a drag link from the R knuckle to the L knuckle...that would be a true cross over...having the tie rod cross down to the drag link is an inverted T style IIRC and dodge used an inverted Y which IIRC is what the TTB use...
Two completely independent tie rods are what makes a true cross over...
Now maybe your confusing cross over and HI steer ????
Take a lookee here and see for your self what I mean
http://www.pirate4x4.com/tech/billavista/Steering/Steering_Research/steeringresearch.htm
