I've had people tell me to vacuum for hours and hours and I've had guys tell me 25 minutes is plenty as long has you have replaced the dryer....Personally, I vaccumed my truck for 20 minutes, charged it with 2lbs 12oz of 134A and it's ice cold. It was 34C (93F) here yesterday - which is about as hot as it gets here in the summer and Dad was more than comfy driving the beast while I sweated like a cat in a chinese restaurant driving my $500 dump truck home.
I hear rumors like that all the time, problem is most people don't understand the reason and principles involved in vacuuming out a system. They think that just getting the air out does the trick. You can get a system to function basically that way , and in your climate, an AC system could be a marginal performer and do just fine, In severe heat climates, you can't get away with that stuff. Even with a real stout pump, on a system that has been open to the elements for an extended time I have seen vapours coming out the exhaust of the pump after over an hour at over 30 inches and let it run a lot longer to every last bit. An average pump that runs at a much lower flow rate and would likely only be pulling 27-28 inches would take all day to get that out ( main reason I spent a fortune to get the stoutest pump made at the time because I do a lot of AC work and the wimpy pump I had was costing me a fortune in electricity to fully evacuate systems)
Think about it, how long does it take to boil water on a stove, you fire up the stove full tilt, and have to wait till it gets to 210 deg f before it starts to boil, then for it to evaporate takes a while from there. Now consider the inside of your ac system. Placing the system under a vacuum decreases the temperature at which the water will boil, in essence you are getting water to boil at room temperature. No easy trick. First the system has to be drawn down till atmospheric conditions in the system are conducive to boiling at room temp, then it takes the time for the boiling to actually begin, once it boils it expands and can be drawn out and that is dependent on the flow of the pump. This all takes a lot of time.
Trying to depend on the dessicant in the drier or accumulator is a non starter because that is only there to handle the very small amount of residual moisture that can remain trapped in a system even after a thorough evacuation, it is never intended to handle the amount of moisture in a system that has not been properly evacuated.
