brokeasajoke
I cant seem to keep enough coolant
in my radiator to cover the holes(
flumes maybe) pushes it out to the
over flow tank. Does not over heat at
allways sits around 2-210 mostly.
System will hold pressure for a
couple of days at least after i shut it
down. Done a 13lb leak test and it
held there and didnt move. Funny
thing is it dont draw the coolant
back in im assuming because of the
pressure it holds. Cracked the cap 2
days after i last drove it and let
pressure out. Edit: 88 7.3 na new
motorcraft t-stat and 13lb cap.
