mankypro
Learning Slowly...
I'm about to install a heat exchanger in my rear large capacity fuel tank. I grabbed one of the stainless steel pick up type the Canucks use on their big trucks.
I need to plumb it with coolant hoses. They say to splice my lines in the same lines as those used by the heater core.
While doing this I'm planning on replacing my existing heater hose lines. I'm wondering what is the best quality hose to use for this? I'm going to use it to plumb the heat exchanger as well. Is there a specific brand or type of hose that is particularly durable and highly resistant to heat/freeze cycles? It will be running along the inner frame and it gets mighty cold in the corridor I'll be running in Northern Colorado/Wyoming/Montana/Idaho - so I want to use high quality hose.
I plan to use brass and ss hose clamps. I was also going to plumb a fuel filter coil heater from this line and I was wondering the effect multiple coolant paths would have on the in cab heating system? It gets mighty toasty in there in any case so a few degrees - like 10-20 would hardly be noticeable - but just wondering about feeding a full size (3/4") T to the rear tank and a smaller (3/8") T to heat the fuel filter and the effect it might have on things.
I attached the pdf file for the fuel filter heater for interested folks.
p.s. not that it particulary matters, but I was wondering which hose line was the supply and which was the return on the heater core as you look at the firewall in the engine bay?
