Changing the coolant -
Install a flush tee in the heater hose that goes between the passengers side head and heater core - hitch up garden hose, remove radiator cap, start engine and turn on hose. Let this go like this until you have clear water coming from radiator.
Now I turn off everything, drain the rad, remove garden hose, drain the block via the block drains, blow air through the heater core backwards and then button everything up except the cap on the flush tee.
Now get some distilled water and diesel approved coolant, I have always used fleetguard brand that is not the extended drain stuff and is not pre-charged with DCA (Diesel Coolant Additive) but you can run whatever you like. System will hold around 6 gallons total (water and coolant). Refill system - enjoy. You might have to burp the system of air - to do this is fairly easy.
Loose rad cap so that it can purge out into the reservoir but not all over the top of the rad/engine. Now start truck and let run for about 20 mins then take for a short drive down the street then come back (don't shut truck off and close rad cap completely) then shut truck off and let cool completely (keep checking the reservoir and topping off as needed) - takes about 3 hours typically. After it has cooled completely check the level in the reservoir and top off if needed - then check rad level top off if needed but you shouldn't need to because it will have pulled from the reservoir during the cooling period.
Now if using the NON precharged coolant remember to add your DCA to the rad as you are filling - 2 bottles. Don't add it to the reservoir because it will take so much time to cycle that into the cooling system.
Come back a few days later and test the radiator (not reservoir) with the test strips and add in more DCA if needed but with adding in 2 bottles from the start you shouldn't need to.
Now for the oil. 15W40 is the recommended all year oil weight. You can run either synthetic or conventional motor oil - it's your choice. Will take 3 gallons with filter change. You can run either the recommended filter size or one from a 95 -97 Powerstroke powered Ford (I want to say this filter number is FL1995 but don't quote me on this - it's been quite a while since I have owned an IDI). The larger filter will fit and it gives a little more filter media comapred to the half sized stock filter they called for.
