Jamie
Over and over I read negative reviews on Autolite GP's and anything other than Beru and Motorcraft. Well, the parts store where I work is an Autolite dealer so I had to find out for myself..... It looks as though I should have listened.
After only three months, and less than one thousand miles I have multiple failed glow plugs it appears. It was too cold out so I cut corners and did a preliminary test with the test light rather than checking resistance. Three out of the four that I checked showed absolutely nothing. I was too angry to check any further.
I guess this sheds light on no starting which had recently developed.
At the same time I installed the plugs, I went ahead and installed a new controller as well. Is it possible the GP failure is a result of a controller failure?
