Clutch
91idi
Fiberglass *****
X
I'
Sycostang67
Scooty Puff Junior
Kuna, ID
I used to run a centerforce clutch in my capri and never had any problems with it. I plan on getting a south bend clutch for my truck though.
Simp5782
SNOW TACKLER!
Western MT
Is there any way around using a single mass fly wheel with their clutch pack? Carquest has a standard clutch kit with the fly wheel, disk, plate, and bearings for 600$. I was looking to have a iron caramic button clutch by a company in memphis for $250 and its under warranty to never fail. Do the old 6.9 and 7.3 run a single mass or are they all dual mass? I can prob find one at a junkyard if i know what years to look for.
DragRag
Los Angeles, California
The smf fly wheel that comes with the t19 will not work with the zf5 unless you buy an 11" conversion clutch that is available with the correct spline sized disc that fits over the zf5 shaft. That clutch I know is available at autozone. I refused to stay with the small 11" clutch, and bought a single mass set up that came with everything for about $400 plus tax. You can be in the smaller clutch set up running your T19 single mass for under $200 though sticking with the 11" clutch.
Bo17
