Building a 6.9 to kill
FordGuy100
Silverton, OR
I think the DB2 will make 400 to the wheels, if i was gonna go drop another 6k on a scheid pump and a conversion kit, i might as well be running a cummins. The whole point of this is to make the build WITH the 6.9.
Bigger lines and injectors just comes with the territory when beefing up an IP.
If I can get a good reliable setup making good power, I wouldn'y give a second thought to running in the street class at a pull. the advantage the f250 has over the rest of the trucks that would be at a pull is weight. in the dodge i could only hang 800lbs of weight before i reached the 8000lbs weight limit. with some attention paid to truck setup, the f250 could hang 2000lbs out front, that is huge!!!!!!!! even if i am coming in with less hp, ALL of it would be getting to the ground,
just make sure with that much weight you are running a Dana 60 LOL.
1994IDI
Destin, FL
I've been watching that exhaust manifolds forum also, apparently no one ever went through with it.
rhkcommander
Oregon
been thinking up some ideas to fab my own, just never made them so playing it slow and steady :eek:
funnyman06
Coventry, RI
haha yeah a D60 is a huge must. In my truck i already have 3000lbs sitting on the front axle. Thats 2WD with nothing special.
jam0o0
houston, tx
just because pistons don't break doesn't mean they are the best top shape available for making power.
i like this idea. i really want to see someone push this motor. machine work on the heads are i think the first place to start.
Hmm...long thread...lots of fluff floating round...will wait n see...as for a "Dirty Pickle" looks more like a Bleeding pickle with that burgundy interior.
Good luck on the build.
Abull78
More boost Mr. Scot
Nevada
Now renamed "Thunder Pickle"
So I made it to Southern California, why is that special? I drove the IDI here!!!!! I really am in love with this pig but, DANG does it suck heading up hills. Heading south on the 15 freeway just after Primm I started heading up the mountains. Best I could manage was 47mph in 3rd gear, we definitely need some power that just aint gonna do. So, after 20 minutes of traveling like that I ordered a Banks kit through my Dodge guy. Engine build or not I need some temporary power.
Up until I had to stop at the California state line at the inspection station I was cruising at 65mph at 2500rpm roughly, that V8 diesel sounds awesome when its humming along. So when i pull through the inspection station I get on the throttle,........whoa, buttdyno alarmn goes off!!!!! I feel more power, I am making less smoke at WOT. The greatness of desnser air being realized. An hour out of San Diego and nearly at sea level elevation hills were no problem, i was actually accelerating up hills, albeit slowly. The Banks needs to get here quick, I cant get use to the truck having this power and then losing in after i get back to nevada and higher elevations.
Oh, and not to shabby on the gas mileage for running 4.10's and 35" tires, total trip was about 17-18 miles per gallon and I am sure its getting a lot better mileage down here than back up in the desert.
Abull78
More boost Mr. Scot
Nevada
One more thing, not to violate the sacred ground of the OB forums but. I found 50 still in the crate 6.5L GM diesels going for pennies on the dollar, any takers?
Abull78
More boost Mr. Scot
Nevada
H1 Hummer motors before you ask.
George D.
Las vegas
State line aint no joke of a grade but its inpossible twoing N/A you physicly cant get the air to burn enough fule in thouse altitude but put a turbo on and its gravy I went from 15 at the bottom to 65 about 3/4 the way up haulling a lot of weight man 3,000 4th gear bigload and straight pipes sounded awsome echoing off the sides of big rigs as I flew past plus listening to them talk about it on the CB was geart after I cussed out the guy that pulled ou on me doing 30 and loseing speed quick passing some other slow mover.
Abull78
More boost Mr. Scot
Nevada
I wonder if a IP from a 9L would be easier to modify being an inline pump?....Just throwing something out there for thought.
gimme some info on the 9L. I will do the research just tell me where to start.
tke395
