block heater
rip van sparky
Fortuna, CA
Has anyone had to replace their block heater? Mine does not work and tests out to be a completely open circuit. I did a cursory inspection and couldn't even see it. It is getting to that point in the year when I'll need it. thanks
Fortunately, block heaters out here (Ca and TX) are not a big issue. be prepared to drop the starter to make your job easier. Its going to be a interesting job due to the fact it might be corodded into place. get your replacement unit first, so you can see how it tightens down. It might very well become a hammer and long drift issue, so have sandpaper to knock down the rust and a tube of silicone to help the rubber gasket to seal up. One more thing, while you are at it, minus well do the thermostat and gasket since the cooling system is opened up.
Diezel_Cowboy
It's not like a real ***!
A little place called "nun a ya binez!"
Mine had a bad plug end.......if you havent already cut the end off and wire a new one up. It would be worth a try and save a lot of work if thats the problem.
Diezel_Cowboy
Alright, plug end first (didn't even occur to me), coolant system surgery second. thanks
Yep, the end didnt have any physical damage to it.....but the block heater was intermittent so I knew there was a bad connection inside the factory plug end. Sure enough when i replaced the end, it worked fine again!
93turbo_animal
Marengo,Ohio
it can also be the end that plugs into the block heater itself so if you buy a new block heater you might try the new cord first when mine quit the plug was bad at the heater a new cord and its all good now
jvencius
In a van down by the rive
When the plug end on my block heater broke off, I replaced it with a battery charger receptacle that I bought from the local marine supply shop. I had to drill a hole in the bumper to mount it, but now I don't have a pigtail plug flapping around in the breeze and connecting/disconnecting is a lot easier without having to reach down for the connection. I think the receptacle cost me ~$17 or so and with the hole saw I had to buy, I was out less than $30 for the whole project and that was money well spent. :thumbsup:
Exekiel69
I got it done too there are pics of the connector to mount on the bumper on my page.
