Pretty funny but also a good question. Also if he did put coolant back in, could there be an air bubble around the heater?ok stupid question...did you fill it back up with coolant?
Especially if the engine hasn't been started yet
Sounds like you answered your own question. The block heater sounds like it kicked the bucket a bit early lol. Did you check the cord that plugs into the block heater? Sometimes they can get corrosion on them and not contact properly. BTW, did you get your jasper all straightened out??
NO if he put coolant in and it's topped up there shouldn't be an air bubble there....
it's simple pull the cord test it with a multi meter if ok...that leaves the heat element or no coolant...rofl...
bout only two things can be really...rofl
