Bio Diesel
hheynow
the misanthrope
SF Bay Area
You will need to replace any fuel lines made of rubber since your vehicle is pre-'93 with a biodiesel compatible hose such as this . Carry an extra fuel filter because the bioD will clean out the #2 diesel mineral deposits lining your tank and fuel lines and will deposit them on your fuel filter. You may need to blend the bioD with #2 to lower the gel point if you have cold morning temps.
dakotajeep
Patrolling
TN/ND
So then my 1994 F350 should be fine with bioD as far as the rubber issue is concerned????....I will change the filter. Thats a lesson I learned when I bought a used pickup and ran fuel treatment through it. It cleaned great and clogged the filter great too which killed my fuel pump!!!!
With talk of a barrel of oil going over $100 soon, I'm going to get ramped up on this soon myself.
dezl
closer than you think
you should be fine, anything built in early 93 should have the lines changed.
dsscrusher
Winnipeg, MB
I too have a 93 F350 and am looking at starting BD. Can I use pure silicone hose for fuel lines? I can get that cheaper (free). It is thick walled suction type tubing.
lewisstevey7
