renjaminfrankln
That is correct, no sleeve on the upper for the rears. You remove the nut and slide the old ones off of the mounting bolt, then slide new ones on. A little WD-40 helps. Trust me I spent about an hour under there last night.
You'll want to get the upper on and get the nut started. To do job yourself id recommend having two jacks. I put my floor jack under the rear bumper and lifted the truck up a few inches so I had less distance to compress the shock. Then I compressed the shock (my shoulder hurts just thinking about this), got it started in the lower bracket, and pinned it in place with a bottle jack. Then used the bottle jack and some gentle whacks with a rubber mallet to get the hole aligned (stick a screwdriver in the hole or an alignment tool).
