spyder1100
Yeah, I got mine at NAPA for 10 bucks each. I actually got the 1110's because they had them all in stock, I just got made some adapters with 10 gauge wire, female blade and male bullet connectors. The problem with our system is the glow plugs are only 6 volt plugs. They heat up very quick because they are supplied with 12 volts. They heat quick, but burn out just as fast. The 1110's that I used are 12 volt, self regulating. They don't heat as quick, but don't burn out very easy either. In comparison, I only have to heat for 15 seconds before I start. On the coldest day here. Just over 0*F. Lights off the first time, every time. Like I said, I had them running at 12 volts, 700 amps for about 15 minutes with no problem. I even bumped up to 24 volts for about 15 seconds and they still looked new. No blistering or swelling.
