JD, the ignition switch has slots, and not round holes, what happens is with time and miles the bolts that hold the switch to the column loosen up allowing the switch to slide down the column a tiny bit, we're talking 1/8" or so, so now at least in theory you'll have to turn the key more to get the rod to slide down those extra 1/8" to hit the "start" position of the switch - problem is that the rod physically cannot move that much, so you max out its travel at what happens to be "run", which is enough to open your FSS and power all electrics except trigger the starter (as it really ain't supposed to, that's why you got your "start" position). In reality your switch works just fine tis just that you can no longer engage it properly through the rod. If you slide the switch in its slots up the column a bit and tighten it there, I will not be surprised at all if that results in you getting back your "start" position up at the thumbler, and everything working good. Starting to make some sense now, or still clear as mud?
For replacing the rod I think you need to pull the steering wheel, and it goes downhill from there. But, like I said, try moving the switch up the column first.
