Alternator Wiring...
I want to change my alternator out to the serpentine type setup. The alternator has a differant wire setup on it than my 89 does with the external voltage regulator. So how do I wire up the new alt to my older wiring setup? Also which alternator should I use. The 95 amp or the 130 amp alternator and why. One is bigger than the other too.
subway
be nice to the admin :D
York PA
why not just change the pulley? i thought the shafts were the same.
Jred... All the pulleys need to be changed. Also the alt mount is differant along with the ac and power steering mount. The vacuum pump is located differantly also. The serpentine belt system is much easier to work on too. You don't have the floppy alternator belt any longer. And the best thing is one belt is all you need as a spare. I will be keeping a spare idler and tensioner behind the seat too.
suv7734
BC Canada
Here's the wiring diagrams for the original (ext. regulator) and later one (int. regulator)
One day we're going to need a pic of behind your seat :D Good thing you have a CC like me!
subway
York PA
sorry, guess i need to think of the bigger picture you have planned.:cool
if i were doing it fresh all things being equal, i would shoot for the higher amp alt. more piece of mind to me having the extra capacity. would be interested to see what it takes to do this up grade since my old 6.9 is a v-belt set up.
dented73
