aaron1976
So, I have been wondering if anyone has a different turbo on their truck than what you can get in a kit from ATS, Banks, or Hypermax?
I have been looking at gm4-gm8 turbos which is an IHI. I have an old ATS now and the prevoius owner didn't see the wisdom in having a good intake setup and so it sucked a lot of dirt and has damaged the compressor wheel. Along with needing a new comopressor wheel, I want to change out the turbine wheel and housing so the turbo will spool sooner. I know every one says I will kill my engine with more sooner but I run the truck at 6,400 ft and the air up here is thin. I am dizzy most of the time it is so thin. It may be easier to get a new or better used turbo.
So I wonder if anyone else has done anything different that works better. Looking for a wg turbo if possible or I could put on external wg but the space is tight for that. A non wg would be fine also.
let us know what you are running and how it works, at what RPM it starts making useful pressure and how much boost it builds and such.
