jaluhn83
Looking for some opinions:
Right now the motor I've got was rebuilt ~30k miles ago and fitted with a custom turbo setup based on a Banks WG turbo. I am fairly happy with the power improvement over the non turbo, but would like to add a bit, especially low end. I'm only making ~5 psi at 2000 rpm and 8-9psi @ 2750 which seems low but we have not been able to figure out why. My suspicion is either a defect in the turbo or losses in the cobbled up exhaust piping I have.
The main goal is to increase low end (1500-2000) rpm torque as much as possible without compromising durability or spending too much money.
I am going to have to pull the motor and replace pistons soon to rectify what seems to be a loose wrist pin and because some of the pistons have damage from a dropped valve right after the first rebuild. I'm planning to have them shaved 0.015" (I calculate this should give ~20:1 cr) and have the crowns ceramic coated. The motor already has head studs, and I'm planning to put one of Russ' torque cams in as well.
I'm also planning to install a proper turbo up-pipe setup, hopefully off a Banks turbo kit if I can find one. The piping I have now is sort of redneck engineered and probably flows poorly, in addition to overheating the clutch slave and locating the turbo too high and fwd. The plan is then to install a larger turbo, possibly a HX/HY35 and intercooler.
So, questions:
1) Any other suggestions while I've got the motor out? I'm not expecting to need any replacement parts other than pistons. The heads were done recently with new exhaust valves. Is there any valve to ceramic coating the valve heads?
2) I've got a line on a HY35 turbo off a 01 cummins. What can I expect from this turbo? I know it's pretty small as far as the holsets go, but since I'm going for low end that should be ok provided it doesn't choke too badly at higher rpm.
3) How well does the HY/X35 fit on our motors? Any major issues?
4) Anyone have experience with "Speed Pro" brand pistons? There's a set on ebay that would work for me for pretty cheap but I want to make sure they're not chinese junk. From what I've found this is a Federal Mogul brand but I've not seen them before.
This truck is mainly used for towing, mostly around 15k gvw with my horse trailer. I'm not looking to make crazy power and don't really care about numbers, the main goal is getting the rig where I want to go reliably and without bogging down too much.
Thanks,
~John
So, questions:
Thanks,
~John
