Abs light, only rear sensor?
MA, cape cod
My abs light recently came on after doing some wheeling. I was thinking it may be the rear sensor, but for the life of me, i cannot remember if this truck has front abs sensors? Is it just one in the rear? Thanks for the help.
1994 f-350
Sycostang67
Scooty Puff Junior
Kuna, ID
Check your fuses as well, a blown brake light fuse will activate the ABS light. I'm pretty sure these trucks never had ABS sensors on the front.
87crewdually
Southern Nj.
Another common thing to check is the wire harness going to the rear ABS speed sensor. It will rub on the shock and chaffe right through the wire. Wheelin multiplies the effect, just thought I'd mention it.
jim_22
Cape Cod, MA
My ABS light came on a while back and it was a loose wire to the sensor which is in the rear.
