I watched the vid again dang is your pump up? are you sure your not hiding a turbo some where even if its remote mounted to your work bench that thing buggies
Thanks guys. The truck is pretty much stock. It's got new BB's that I matched myself, A fairly recent dieselogic pump turned up one flat. Straight exhaust with glasspack, No soup bowl, Timed to 9 degrees and 3.55 gears. Mostly just your basic stuff.. I'd love to have a turbo but the plans are to do a zf5 swap first. I'm very happy with it considering it's n/a with a c6.
Yea it is faster. Just watched a vid of mine and then yours even with the wheel spin seems pike 1/4-1/2 second faster. Maybe something is up with my truck who knows
You cant tell it in the vid but that tranny shifts very firm. If you look you can see I it shifted manually right on the governor each time, It wont hold gears that high itself.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
