nevrenufhp
torque ******
The best way to describe the 0 plate is to compare a before & after. One is a stock plate, the other is just after I ground it down. Take the flat spot just above the little bunps, and you're just making a line straight down. Then, once you get done, take the AFC housing off the truck(remove the boost line), and grind down on the lever on the AFC that rides with plate. Hold the plate up where it sits in the truck (except upside down), then mark the extra with a sharpie & grind that portion down to match your new #0 plate. Be sure to clean all areas of foreign material(metal bits & shavings) before reassembly.
