94 idi f350 ac high pressure switch
DiecellDan
Tx
My ac clutch is popping in and out of power. I found the pigtail to the high pressure switch to be bad. I'm having a very hard time finding the part. Anyone know the part number or a good aftermarket connector? Don't really want to mess with junkyards..
PS. The connector is so worn that I can't read the part number. Went to ford to find lay motorcr
DiecellDan
Tx
**went to ford to find out that the part has been discontinued**j
I literally just had this same issue.
First it was my clutch pigtail. So I wasted the $30 on that at orielly when I could've got it online for $5.
For the high pressure switch, I pulled the pins, cleaned them, and squashed them down a bit.
Spade connector won't really work. 1. Doubt it'd fit. 2. They are round pins.
Or could just do this. https://www.oreillyauto.com/detail/...rness-connector/37235/4517680/1994/ford/f-350
chris142
SoCal
Thats a safety incase the high side gets over 400 psi. You can twist the wires together for now until you can find the connector.
DiecellDan
Tx
The one on My truck has 2 pins. Will this still work?
Yeah. It's just a generalized plug. The extra wires were for cars that had helper fans.
DiecellDan
Tx
Hey man Thx. I installed the pigtail. Ac works again! Thx a bunch.
Garbage_Mechan
Garbage Mechanic
Central Cal Foothills
I got tired of this game after the second time I went to my HD equipment and truck AC supplier and found a switch with same pressure rating but has a common Deutsch connector on it. The I put a deutsch on the harness. Much wore vibration proof. Made for big rig environment.
Tyler9828
